GE HealthCare - Aestiva/5
by GE HealthCare
More than superior ventilation.
The Aestiva 5 offers exceptional capabilities and flexibility, giving a cost-effective approach to anesthesia therapy.
The Aestiva 5 with SmartVent offers users selected capabilities of an intensive care ventilator, saving users the cost of bringing a separate ICU ventilator into the OR. Its flexible ergonomic design and intuitive operations enhance SmartVent's capabilities to give users a higher level confidence and control. In addition, the Aestiva/5 provides an optimized system for the practice of low and minimal flow anesthesia, minimizing agent consumption to save on anesthetic agent costs.
The Aestiva 5 open architecture gives users the flexibility to use their current monitors and data management systems, helping users stay within their budget while achieving physical integration in one unit. The Aestiva/5 also has built-in service diagnostics making service support easy and cost efficient.
1ReplySat Feb 08 2025 | Sodasorb Hello, my name is Blanca Mendoza, I am the Anesthesia Technician at MacNeal Hospital in Berwyn, IL. my question is in regard to the Sodasorbs. Can you please send me a quote and/or a reference number for them? Thank you so much, Blanca Mendoza Equipment: Datex-Ohmeda Aestiva / 5 Reply |
2RepliesWed Jan 03 2024 | back pressure tests need proper method for a back pressure check test. Equipment: Datex Ohmeda - Aestiva/5 Reply |
1ReplyThu Dec 14 2023 | Change default settings for vent Hi I am looking to change the default setting for our ventilator and alarm settings. Are there instructions to do so? Thank you Reply |
Superior ventilation
Open systems architecture
Innovative patient breathing system
Improved low flow/reduced life cycle costs
| Height | 52.9 in |
| Length | 28.7 in |
| Vaporizers (Max) | Three |
| Scavenger | Closed interface |
| Weight | 238 lbs |
| Vaporizer Type | Variable-bypass |
| Vent Modes | VCV, PCV, SIMV (optional), pressure support ventilation (PSV), Manual/Spontaneous. |
| Width | 28.3 in |
