Advertisement
Dräger - Narkomed 2B
Manufactured by Dräger
The most popular machine ever sold to date.
The NAD Narkomed 2B is one of their longest running and most reliable model lines. The 2B has O2 and N2O standard with optional medical air and holds 3 vaporizers. An AVE ventilator with F-Style ascending bellows is a standard feature with oxygen, volume & pressure monitoring. Drawer pack configurations may vary from picture.
QUESTIONS & ANSWERSView All
2
Answers
-olivegreensushi
a year ago
ventilator switch
I can't move the lever from bag to auto to place the patient on the ventilator. Vent know is in the On positionReply
Answers
-dt.arnold
2 years ago
narkomed 2b tubing connections
hi,im having problem with the tubing connections of my narkomed 2b.already checked it in tech manual but didnt see any diagram of gas selector switch and ormc.can anyone help me with this?please...thank you,arnoldReply
2
Answers
-Melso
2 years ago
How to silence alarms under specific circumstances.
I am in a pain clinic where all cases are MAC. We use the Narkomed 2b as a back-up in case of emergency, but 99% of the time only utilize the aux. O2. However the machine is turned on and checked daily. How do you silence the alarm that goes constanly saying %02Low, etc. You can silence for 120 seconds, but it is annoying to have to press the silence alarm button every 2 min during a 10 hr day!! What is the trick to silencing that alarm for the duration, yet keeping the machine ready to go as needed?Reply
DOCUMENTS / MANUALS
PREVENTIVE MAINTENANCEView All
3
Answers
-Ron Morey
3 years ago
Tubing replacement tip
I have found a simple trick to aid when replacing tubing on the NM2, 3 and 4's. I use a heat gun to turn the opaque tubing clear. It is best if you have a small diameter welding nozzle on the gun. The tubing is more flexible after treatment. This avoids the problem of having multiple lines breaking as I am attempting to change them one by one. I have found this helpful. I hope you do as well. Only heat the tubes till they are clear, any further runs the risk of melting the tube. Also care must be taken when the line runs past wires or electronics. Any residue displaced should be vented during post replacement testing. All the best, Ron.Reply
  1. Ventilator options:Pneumatic or electronic, ascending or descending bellows
  2. Oxygen monitor and CO2 absorber standard
  3. AVE Electronic ventilator
  4. Absorber and scavenger
  5. Oxygen analyzer
  6. Breathing pressure monitor
  7. Respiratory volume
  8. Centralized alarm and data
  9. Oxygen ratio controller
  10. Pressure limit controller
GasesAir, Nitrous Oxide, Oxygen
ScavengerOpen or Closed Interface
Vaporizers (Max)Three
Vent ModesVCV, Manual/Spontaneous. Mechanical/pneumatic
Height68 in
Length 25 in
Weight325 lbs
Width40 in
NEWSView All
!{article.title}
Class 1 Recall: Dräger Evita V500 and Babylog VN500 Ventilators -...
Dräger is recalling the PS500 battery power supply because a software issue causes shorter than expected battery run times.
!{article.title}
Dräger Earns Respiratory Care's Highest Honor for Seventh Straight...
Dräger Earns Respiratory Care's Highest Honor for Seventh Straight Year – AARC Zenith Award
!{article.title}
Dräger Introduces Innovian Anesthesia 4.1 with remote access option
New Mobile Report Viewer capability enables clinicians to securely access data collected by Dräger’s AIMS on Web-connected devices over the healthcare facility’s wireless network
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
