Draeger - Narkomed 2C
The unit was built on the same familiar Narkomed style frame and offered AV2+ ventilator that was a volume ventilator but offered pressure limiting and reverse IE ratios. The unit had 3 vaporizer mounting positions for the 19.1 style vaporizers. The 2C utilized a remote screen and data grip on an articulating arm to display the volume, pressure and oxygen data as well as trend and alarm information. The unit is 5” shorter than its predecessor the 2B due to moving the display on the arm. The machine had a 3 drawer cabinet, absorber with PEEP and auxiliary flow meter. The unit is easily maneuvered and a great choice where machine height is an issue.
FORUMSView All (8)
0Replies5 years ago | Tubing Dimensions? Need to replace brittle tubing. What are the dimensions for the two sizes of tubing? Service manual only lists 1/8" Tygon. Doesn't list both sizes and doesn't specify inner and outer dimensions.Reply |
1Reply8 years ago | Narkomed alarm Please, what is the meaning of "NETWORK DOWN" alarm in the Narkomed 2A equipment? Reply |
1Reply9 years ago | service manual Reply |
- State-of-the-art platform machine equipped to interface with a full range of patient monitoring devices.
- The first mid-range anesthesia system to provide a fully adjustable remote display that presents real-time numeric and waveform information, centralized alarm massages and configurability to various display formats.
- 19.1 vaporizers
- AV2 ventilator
Gases | Air, Nitrous Oxide, Oxygen |
Vaporizers (Max) | Three |
Scavenger | Open or Closed Interface |
Weight | 425 lbs |
Vaporizer Type | Variable-bypass |
Vent Modes | VCV, Manual/Spontaneous. Mechanical/pneumatic |
