Draeger - Narkomed 3
Cost-effective full featured machine.The built-in monitors on this anesthesia machine are the key feature. The Narkomed 3 is equipped with AVE ventilator with ascending bellows. Oxygen, volume and pressure monitoring are standard but can be configured with optional monitoring for endtidal CO2, pulse oximetry, non-invasive blood pressure, and agent analysis. Drawer pack configurations may vary from picture.
FORUMSView All (7)
1Reply7 years ago | i need service manual, pleasethe ventilador is not run gree led power on is off Reply |
0Replies8 years ago | Narkomed 3 Breathing Pressure Gauge - Connection Thread Specs Hello, I am trying to replace several breathing pressure gauges on some older Narkomed GS anesthesia systems (Part #4105853-Drager Absorber Gauges). These display pressure in the cmH2O range. Does anyone know what the thread specifications are for this gauge (e.g., standard or metric pipe threads, standard or metric UN/UNF straight threads, thread size and pitch, etc.) ? Thank you in advance. Reply |
3Replies10 years ago | To get spare parts Message E07 in section agent and CO2. So, I'm thinking is the multispec analyzer board, so I would like to know if this board is in the market yet. Thanks! Reply |
[list] [*] AVE Electronic ventilator [*] Absorber and scavenger [*] Oxygen analyzer [*] Breathing pressure monitor [*] Respiratory volume [*] Centralized alarm and data [*] Oxygen ratio controller [*] Pressure limit controller [*] AVE Ventilator [*] CO2, NIBP, and SPO2 monitoring [/list]
Height | 68 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 40 in |
Vaporizers (Max) | Three |
Scavenger | Open or Closed Interface |
Weight | 400 lbs |
Vent Modes | VCV, Manual/Spontaneous. Mechanical/pneumatic |
Width | 25 in |
Standard Gases: The Narkomed 3 is equipped with pneumatic circuitry for the delivery of oxygen (o2) and nitrous oxide (N2O). It has at least on oxygen and one nitrous oxide yoke for reserve gas cylinders with flush-type valves. The Pin Index Safety System prevents connection of a cylinder of the incorrect type. Option Gases: In addition to oxygen and nitrous oxide, the NARKOMED 3 may be equipped with up to two additional gases. The additional gas may be air, helium, (He), nitrogen (N2), or carbon dioxide (CO2). The additional gas may be supplied to the anesthesia system by means of pin-indexed cylinders and yokes, by Diameter Indexed Safety System (DISS) pipeline connections, or by both systems, if so selected.
