Draeger - Narkomed GS
Durable anesthesia workstation that is intuitive and easy to use.Built-in monitor displays volume, pressure and O2 data. The monitor features a centralized three-tier alarm system that helps physicians quickly recognize critical events.
Includes the dependable AV2+ ventilator, which is pressure-limited, time-cycled and volume-preset. It features pneumatic circuitry and electronic timing, plus controls for breathing rate, inspiratory to expiratory ratio, tidal volume, inspiratory flow and inspiratory pressure limit for flexible ventilation. It is capable of inverse I:E ratios with its built-in safety mechanism and is designed for an assortment of conditions. It also uses an economical amount of drive gas.
FORUMSView All (24)
1Reply5 months ago | Recovey system Narkomed Gs The narkomed worked correctly until when I turned it on, the system no longer started. I checked the processor battery and it was low. I replaced it but the system remains the same. Does anyone know how to reset the system? thank you Reply |
0Replies10 months ago | Testing Ram Fail Al inciar la pantalla me sale "testing Ram Fail ", ¿alguien podria darme solución porque sucede eso? Reply |
0Replies3 years ago | TESTIN RAM FAIL Afte power on show this message, any one know how can i solve the problem?Reply |
- Two or three vaporizers
- Absorber
- Scavenger system
- Sphygmomanometer
Height | 53.25 in |
Gases | Air, Nitrous Oxide, Oxygen Helium, and Carbon Dioxide |
Length | 27 in |
Vaporizers (Max) | Two |
Scavenger | Open, Closed or Passive interface |
Weight | 375 lbs |
Inspiratory Flow (max) | 100 L/min |
Vaporizer Type | Variable-bypass |
Vent Modes | volume control (VCV), Manual/Spontaneous |
Width | 36 in |
ANESTHESIA AGENTS:Isoflurane, halothane, enflurane, desflurane, sevoflurane
