Draeger - Narkomed GS
by Draeger
Durable anesthesia workstation that is intuitive and easy to use.
Built-in monitor displays volume, pressure and O2 data. The monitor features a centralized three-tier alarm system that helps physicians quickly recognize critical events.
Includes the dependable AV2+ ventilator, which is pressure-limited, time-cycled and volume-preset. It features pneumatic circuitry and electronic timing, plus controls for breathing rate, inspiratory to expiratory ratio, tidal volume, inspiratory flow and inspiratory pressure limit for flexible ventilation. It is capable of inverse I:E ratios with its built-in safety mechanism and is designed for an assortment of conditions. It also uses an economical amount of drive gas.
FORUMSView All (24)
-Semeeq
5 months ago
Recovey system Narkomed Gs
The narkomed worked correctly until when I turned it on, the system no longer started. I checked the processor battery and it was low. I replaced it but the system remains the same. Does anyone know how to reset the system? thank you
-yira
10 months ago
Testing Ram Fail
Al inciar la pantalla me sale "testing Ram   Fail ", ¿alguien podria darme solución porque sucede eso?
-Pablorv
3 years ago
TESTIN RAM FAIL
Afte power on show this message, any one know how can i solve the problem?Reply
  1. Two or three vaporizers
  2. Absorber
  3. Scavenger system
  4. Sphygmomanometer
Height53.25 in
GasesAir, Nitrous Oxide, Oxygen Helium, and Carbon Dioxide
Length 27 in
Vaporizers (Max)Two
ScavengerOpen, Closed or Passive interface
Weight375 lbs
Inspiratory Flow (max)100 L/min
Vaporizer TypeVariable-bypass
Vent Modesvolume control (VCV), Manual/Spontaneous
Width36 in
ANESTHESIA AGENTS:Isoflurane, halothane, enflurane, desflurane, sevoflurane
