Draeger - Narkomed MRI-2
The complete anesthesia solution for the MRI environmentThe Narkomed MRI is the only anesthesia system with an integrated ventilator and VPO monitor, designed and engineered to perform, without distance or electromagnetic restrictions, in shielded or unshielded MRI environments of up to 3.0 Tesla. This feature allows operation with the shortest possible distance between the patient and the machine; a very important consideration when scanning pediatric and neonatal patients. The powerful magnetic fields that create detailed patient images, can create substantial problems with standard anesthesia equipment. Even when placed in direct contact with the MRI, the Narkomed MRI works dependably and produces no detectable image distortion. The machine combines an integrated electronic ventilator and an integrated exhaled volume, airway pressure and oxygen monitor in one compact unit.
FORUMSView All (7)
0Replies7 years ago | CE certification or mark Does this product have the CE certification?Reply |
0Replies7 years ago | Drager MRi 2 won't shut off The on/off switch alarm channel has been replaced and still will not shut off. Any ideas? Reply |
5Replies9 years ago | Narkomed MRI parts compatibility with Narkomed 2 I have a Narkomed 2 for which I can find no documentation. Is the absorber dust cap (4106874) listed in the Narkomed MRI service manual compatible with the Narkomed 2? Reply |
[list] [*] Ventilator: Ascending bellows pneumatic double-circuit AV2+ style ventilator without tidal volume compensation. Modes volume control (VCV), Manual/Spontaneous. Mechanical "bag/vent" switch. [*] Machine checklist: Manual FDA-style checklist. [*] Flowmeters: Traditional needle valve with glass flowtube display. [*] Breathing circuit: Traditional absorber head. The breathing circuit is higher volume (dual absorbent canisters). May use loose granules or prefilled canisters. May be used with non-rebreathing circuits. [*] Electrical power failure: Most functions except patient monitoring are preserved during power failure, as this is a basic pneumatic-mechanical machine. [/list]
Height | 53 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 27 in |
Vaporizers (Max) | Two |
Scavenger | Open, Closed or Passive interface |
Weight | 230 lbs |
Inspiratory Flow (max) | 100 L/min |
Vaporizer Type | Variable-bypass |
Vent Modes | volume control (VCV), Manual/Spontaneous |
Width | 31.5 in |
ANESTHESIA AGENTS : Halothane, isoflurane, enflurane, sevoflurane
