Draeger - Julian
by Draeger
Attractive, state-of-the-art unit with built-in ventilator and two vaporizers
The flowmeters are one of the more unique features of this machine. Total fresh gas flow, carrier gas (nitrous oxide or air), and desired inspired oxygen concentration are set. Entirely electronically controlled; no needle valves or glass flowtubes. Digital numeric flow display, and optional graphic display of each flow on a seperate screen. Electronic capture of fresh gas flows. No minimum oxygen flow, electronic hypoxic guard system. "Safety O2" flowmeter as mechanical backup.
FORUMSView All (7)
-Papa Njaay
7 years ago
How to change the language in French and the service manual
Does anyone know how to change the language in French and the service manual of anesthesia machine Julian plus Drager Reply
-Kyasa
8 years ago
Drager Julian plus anesthetic machine
I HAVE JULIAN PLUS ANEASTHETIC MACHINE IT SHOWS OXYGEN FAILUIRE AND LEAK TEST FAIL WHAT COULD BE THE PROBLEM
-Kyasa
8 years ago
Another problem with this Julian plus anesthetic machine is it doesn't pass leak test  what could be the problem
[list]   [*] Cylinder Yokes N20 Pin   [*] Auxiliary Oxygen Flowmeter   [*] Vaporizer Support Parking   [*] Bag Mount - Fixed Bag Arm   [*] Patient Line Boom Arm   [*] Boom Arm Mount   [*] Storage - External Drawer   [*] Mounting Options - Monitoring   [/list]
GasesAir, Nitrous Oxide, Oxygen
Vaporizers (Max)Two
ScavengerOpen interface
Weight198 lbs
Inspiratory Flow (max)75 L/min
Vaporizer TypeVariable-bypass
Vent ModesIMV, manual,spontaneous, PCV
