Datex Ohmeda - ADU Plus Carestation
by Datex Ohmeda
The ADU Plus Carestation is an innovative approach to anesthesia delivery, which utilizes electronic control for both gas delivery and vaporization. This enables full benefit of the automatic data capture of care information management and minimizes manual documentation.
7Replies5 years ago | ventilator checking Goodmorning, I have an Adu S5 carestation, when I do the initial check the ventilator fail its. Then after 3 or 4 times it start correctly. Maybe it is an electrical problem? can I resolve it? thanksReply |
0Replies9 years ago | The ADU doesn´t pass the self test Hi I have a Datex Ohmeda ADU s/5, but when it performs the self test, it stays in that state, I tried to see the diagnostic page under setup but a password is asked
Does anybody has the Calibration and diagnostic password??, and does somebody has have the same problem? Reply |
5Replies9 years ago | caliberation password Hi I have an Ohmeda ADU plus anesthesia work station, it went into selftest, and it remains in this state, the service manuals said that insipratory valve is the problem , I need to calibrate it, password is mandatory, any body have it, please Reply |
Height | 66.7 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 30.7 in |
Vaporizers (Max) | One |
Weight | 286 lbs |
Vaporizer Type | Electronic control |
Vent Modes | Pressure Control (PCV), Volume Control (VCV); and spontaneous ventilation modes: Pressure Support (PSV), Synchronized Intermittent Mandatory Ventilation (SIMV) |
Width | 33.1 in |
