Datex Ohmeda - Modulus II
Provides oxygen and volume monitoringFORUMSView All (7)
2Replies4 years ago | Datex ohmeda modulus II plus Machine shows there is low oxygen supply but gauge reads 50Reply |
1Reply9 years ago | Anesthesia Machine parts Does anyone have access to an older Ohemda machine switch? The number is PXB B1911se. IT is from a Ohmeda Mod II. It is a part of the system on/off switch and I believe it's function is to release the pressure on the flow tubes when the machine is turned off. Needed for Machine in Mission Hospital in the Dominican Republic. |
1Reply10 years ago | Reset floppy Disk Urgent. Kindly assist me with reset floppy for my datex ohmeda modulus II,it's urgent please.The ventilator is,7850 Ventilator stock number,1500_8005_000.Serial number CAVT00255.Kindly assist it's urgent. Reply |
[list] [*] Double Flowmeter Tubes (O2 & N2O) [*] Flowmeter Protection Shield [*] Link-25 Hypoxic Guard [*] Touch-Coded Oxygen Knob [*] Oxygen Supply Pressure Sensor / Alarm [*] Oxygen Supply Pressure Failure Device [*] A.C. Line Power Sensor / Alarm [*] D.C. Power Sensor / Indicator [*] Selectatec® 3 Vaporizer SM Manifold [*] Minimum Oxygen Flow [*] Anti-Disconnect Fresh Gas Outlet [*] 3 Drawer Lockable Cabinet [*] Integral Footrest [*] Integrated D.I.S.S. Pipeline Inlets [*] Modular Oxygen & Nitrous Oxide Yokes [/list]
Height | 61 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 25.2 in |
Weight | 477 lbs |
Vaporizer Type | Variable-bypass |
Width | 34.5 in |
