GE HealthCare - CARESCAPE B850
by GE HealthCare
The Evolution of Care
The CARESCAPE Monitor B850 is a high-acuity monitor that can help you manage your patient flow by providing data continuity and integration across care areas. Its intuitive design allows for easy training for all staff experience levels, and the monitor is upgradeable. The B850 is intended for use on adult, pediatric and neonatal patients and on one patient at a time. The monitor provides alarms, trends, snapshots and events, and calculations and can be connected to displays, printers and recording devices. The CARESCAPE Monitor B850 can be a stand-alone monitor or interfaced to other devices. It can also be connected to other monitors for bed-to-bed viewing and to data management software devices via a network.
FORUMSView All (9)
-fatih044
Fri Dec 05 2025
B850 S/5 Computer Interface stop responding data request
Hello everyone
I am trying to retrieve data from a b850 patient monitor using the S/5 Computer Interface. For the connection, I am using a PL2303-based Glink USB RS232 converter -->Female Female Null Modem-->USB-RS232 converter-->Raspberry Pi. Initially, I receive a response when I send a message to retrieve data, but sometimes after 8 minutes, sometimes after 24 minutes, and sometimes after 2 hours, the data flow and response to requests stop. In this case, I cannot get a response again without removing the USB from the error monitor. Has anyone else encountered a similar situation? Why is this happening? I can see the USB serial converter device in the system, but the CTS pin on the RS232 converter in the error monitor is constantly at a low level.
Equipment: GE HealthCare - CARESCAPE B850
-JAYC
Fri Apr 06 2018
Carescape b850 , edwards hemosphere ,capsule integration
I recently ran into a situation with these 3 devices. Please beware when integrating these 3 devices. The carescape b850 by default can not slave cvp to the new hemosphere cardiac output monitor. The system will only slave ecg and arterial pressure. The unity network for ge will be able to pull the cco from the edwards monitor. You will need a serial to ethernet adapter made by GE to do so. The problem with this configurantion is that the only port available to send the cco to the unity network is also the only port used by the hemosphere to send the data to capsule. In order to get both the cco info to the b850 and the data to capsule you will need a male to 2 females "y" db9 splitter and the vigilance serial cable along with the db adapter from capsule. You will also need to match the baudrate in the edwards monitor to 19200. After this is configured you will be able to see your cco,cci,svr and svri on your b850. The crna will still have to enter the svr and svri manually unto epic but they will have continuous monitoring. Edwards is working in a solution for this problem. Ge do not have a solution for it. Capsule, maguire enterprises and black box do not have a solution for this problem.Reply
2
-Robert Quick, CBET, USAF Ret.
Wed Jun 07 2017
Software upgrade install
Does anyone have the Software installation guide for the B850??Reply
SERVICE COMPANIESView All Telemetry-Central Station Companies
Connectivity to other systems helps in getting the necessary data to the point of care. The ability to access information within and between departments can help improve nursing workflow efficiencies. [list] [*] Information access to clinical data and data entry with patient centric bidirectional CARESCAPE iPanel that offers access at the bedside to lab results, diagnostic images and any patient data available on the enterprise system. Using separate networking and Citrix® application, the access is fast. [*] Linkage to other storage systems (EMR via HL7®, 12-lead to MUSE®) puts data where it needs to be [*] Patient-centric access to data at bedside with CARESCAPE iPanel, which means enhanced efficiency at finding the right data for the right patient [*] Easy access to view and get alarms of the other patients in the other OR or PACU with AVOA. Anesthesiologist can view patients that are recovering in PACU or in other OR and managed by a nurse [/list]
NEWSView All
Product Showroom: Critical Care Monitors
This month, Medical Dealer explores current trends in critical care monitors.
University of Colorado Hospital Deploys CARESCAPE Monitor B850...
Implementation of GE Healthcare CARESCAPE Monitor B850 Helps Improve Caregiver Access to Patient Information and Supports NICU-Specific Clinical Priorities WAUKESHA, WI, FEBRUARY 28, 2011-GE Healthcare today announced that the University of Colora
