Philips - IntelliVue MX800
It’s a patient monitor. It’s a clinical informatics workstation. It’s a revolution.The Philips IntelliVue MX800 incorporates patient monitoring and clinical informatics to simplify access to the patient information. The MX800 features an integrated PC for one intuitive view with clear patient status and relevant clinical information at the bedside, allowing caregivers to send and receive patient information across modalities. The monitor and PC are concurrent and independent. Information can be accessed from the hospital intranet or PC applications at the bedside while monitoring patient vital signs. Fully compatible with the IntelliVue family of patient monitors, and with the same intuitive user interface, the MX800 can blend into an existing IT infrastructure. The IntelliVue MX800 is designed with smooth surfaces and a minimum number of seams, and is easy to clean to reduce the risk of cross-contamination.
FORUMSView All (20)
3Replies3 years ago | need IntelliVue MX750 and MX850 I need Philips IntelliVue MX850 and MX750.Reply |
0Replies3 years ago | Pairing a remote to an MX800 Hello, does anyone know the procedure for pairing a wireless philips remote to a bedside monitor. I know it's done in service mode. Thanks for your help. Reply |
4Replies4 years ago | Integration I have CMS that i need to integrate with the Philips - IntelliVue MX800,so that the wavelength and parameters can be seen on my CMS. I have been able to set up the ip address on the Philips - IntelliVue MX800 but am not able or cannot see where i can set my CMS ip address on the Monitor. Is this equipment integratable with other CMS and can i also send the records to PACSReply |
SERVICE COMPANIESView All Telemetry-Central Station Companies
Separate but together
The monitor and PC are concurrent and independent. Quickly and easily access information from the hospital intranet or PC applications at the bedside with no compromise to patient vital signs monitoring or clinical alerts.
Easy to use
Fully compatible with the IntelliVue family of patient monitors, and with the same intuitive user interface, the MX800 can blend easily into your existing IT infrastructure, helping you to make the most of time, talent, and resources.
More actionable information at the point of care
Exceptional integration of monitoring and iPC computing capitalizes on next-generation “IT-centric” bedside applications, with a broad range of Clinical Decision Support tools for your team. The MX800 is highly configurable and widely scalable.
Reduces the risk of infection
NEWSView All
Product Showroom: Critical Care Monitors
This month, Medical Dealer explores current trends in critical care monitors.
Philips IntelliVue MX800 Brings Patient Data to One Screen
Philips has introduced a new patient monitor, the IntelliVue MX800, that provides common vital sign data, but that can also display information coming from any other hospital database. The product essentially acts like a bridge that can deliver together patient information from different sources right to the point of care. From the announcement:...
