STERIS - AMSCO Eagle 10
by STERIS
Safe, fast and dependable sterilizer.
Amsco Eagle Ten Autoclave provides clinics with Safe, fast and dependable sterilizer. The Amsco Eagle Ten Autoclave is a large capacity, counter-top sterilizer perfect for any size practice.  The outside dimensions are compact, saving counter space in the work area. Simply select wrapped, unwrapped, packs or liquid sterilization with the touch of one button.
FORUMSView All (32)
-Biomed_FST
Thu Jul 10 2025
Unit does not pass Pulse 1
Hello, I have sterilizer that wont go pass Pulse 1. There is excessive steam coming out and going to the drain. Any thoughts on what it could be?
Equipment: Steris Eagle 16inch
-Mvpcuba
Tue Jun 17 2025
Temp reading unstable and blinking on display
Hope someone can help me with this problem. I have a AMSCO Eagle 10 autoclave which the 5V power supply went bad and replaced for another 5V 3A power supply. The problem now is that the temp reading is unstable and the digits are blinking on the display. The temp reading doesn't goes over 102 C and is giving error code E98. I removed the thermistor connection and when checking the temp reading on menu F1, still unstable and blinking.
Thanks in advance
Equipment: AMSCO eagle 10
-RCD
Wed Aug 21 2019
Need technical manual
Looking for a technical manual for Amsco Eagle 10Reply
  • Safe, fast and dependable sterilization
  • Large capacity, compact design
  • Microprocessor controls
  • Self-diagnostic error codes
  • Safe operation
  • Fast sterilization cycles
  • Pre-programmed or programmable cycle selection
Height20.5 in
Length 15.5 in
OrientationBenchtop
Weight80 lbs
Width19.75 in
  • The spacious 10" x 16" chamber can hold two utensil trays per load for wrapped, unwrapped and liquid goods.
  • Other features include optional programmable controls, self-diagnostic error codes and safe operation.
