STERIS - AMSCO 613-R Dynaclave
by STERIS
Fast and efficient.
Able to heat up to the germ-destroying temperature range of 250°F  270°F, the Amsco 613-R Dynaclave is also fast and efficient, reaching operating temperature in as little as ten minutes. The Amsco 613-R Dynaclave features two furnished tool trays with the space to insert a third, ensuring that you will be able to sterilize many  if not all  of your tools at once. With a built-in exhaust system which channels residual steam and water back into its attached water reservoir, the Amsco 613-R Dynaclave is also safe for your patients and staff, ensuring an absolute minimum of exposure to dangerous post-sterilization fumes.
-svador
11 years ago
new owner
Ijust purchased a used dynaclave but the instruction manual was not included. Can anyone help with operation?
  • Fast, safe, and simple sterilization
  • Large interior chamber capacity (up to three tools trays at once)
  • Lightweight – although the is capable of heavy-duty sterilization, it’s easy to move around the office
  • Easy functionality: Simply start the automatic 60-minute timer, which controls cycles varying from 3 to 60 minutes
OrientationBenchtop
