Barnstead - Harvey Chemiclave MDT EC6000
Medium/large-sized, compactly-designed chemical autoclave unitUnlike most sterilizing hardware, the Barnstead Harvey Chemiclave EC6000 doesn’t use steam to sterilize instruments, which can shorten their lifespan and cause them to rust over time. Instead, the Barnstead Harvey Chemiclave EC6000 uses Vapo-Steril, a compound made up primarily of alcohol, to sterilize equipment. Not only will your tools never come into contact with steam, but you’ll be able to use them faster, too – no drying cycle is required with any Chemiclave unit.
FORUMSView All (11)
1Replya year ago | Expanded Dental Assistant Any idea on where to find Harvey Chemi Clave filters- order part 261569Reply |
3Replies4 years ago | Not heat Power is on. But The unit does not heat or pressurized. The liquid comes out from the chamber. Reply |
2Replies6 years ago | Pressurize Unit is not building up pressure past 12 PSIReply |
- Chemical sterilizer – won’t damage your tools over time like steam can and helps tools maintain sharp edges for longer
- Manually controlled
- Compact size will fit on most countertops
- No drying cycle required
- Fast – up to 20 minutes quicker than similarly-sized steam sterilizers
- Preheating option to further reduce cycle time
Orientation | Benchtop |
