Napco - 8000-DSE
by Napco
Compact, portable unit for sterilizing liquids, solids, and instruments.
Compact, portable unit for sterilizing liquids, solids, and instruments. Features a slow cool-down cycle for solids and instrument sterilization, this slow cool-down capability prevents liquids from boilover as pressure within the chamber is vented at the end of the sterilization cycle. Equipped with a built-in drying element for rapid moisture removal after sterilization. The units main heater is submerged in water, thus eliminating the "cracked" or "burned-out" catastrophic chamber failures, common in autoclaves with non-immersed heaters. Unit has a 70 min cycle timer for automatic operation.
FORUMSView All (4)
-BHayns
Fri Apr 11 2014
Operational/Service Manual Needed for Autoclave
Hi, I have just purchased a used National (NAPCO) 8000-DSE Autoclave Sterilizer. It doesn't have a manual. Would anyone have a link to download this manual? I would very much appreciate the help. Thank you.
-RChurchill
Tue Jul 02 2013
User Manual?
-tulioeb
Wed Mar 07 2012
Service manual
Service manual
Height14.5 in
Length 27 in
OrientationBenchtop
Weight90 lbs
Width18 in
