Pelton and Crane - Delta Q8
by Pelton and Crane
Automatic Autoclave
An automatic chamber pre-heating function can shorten cycle times by as much as 50%. Closed-door filtered air drying ensures that both your packs, pouches and unwrapped tools will be fully dried without being exposed to airborne contaminants. The electronic, microprocessor-controlled monitoring system even ensures that sterilization settings and conditions are optimal at all times. The Delta Q8 even has an ergonomically-designed, user-friendly handle.
[list]   [*] Closed-door drying dries equipment without contaminant exposure   [*] Accommodates up to three large and three small standard cassettes at once   [*] Ergonomically-designed handle to keep your staff – and your tools – in top condition   [*] Optional PC cable to record data without the need for a costly printer   [*] Automatic pre-heat function to cut down on cycle times   [*] Four automatic settings with an optional, programmable custom setting   [*] Automatic monitoring system automatically vents chamber should pressure exceed 240 kPa, with an additional safety backup at 262 kPa   [*] Chamber automatically vents into the atmosphere in case of power loss   [*] Surface sensor monitors internal temperature with overheat protection if chamber exceeds 180C   [*] Designed and built to meet ASME specifications   [/list]
OrientationBenchtop
