Pelton and Crane - Validator 8+
by Pelton and Crane
The Pelton & Crane Validator 8+ Autoclave is a economical, light-capacity sterilizing unit designed to accommodate the needs of small medical, dental, and other practices requiring reliable and safe access to sterilization equipment. Incorporated are a variety of safety and efficiency features, such as a door lock, which prevents the door from being opened while the chamber is pressurized. The Validator 8+ Autoclave also features a set of microprocessor-controlled features to ensure effective and safe operation; a vent valve will automatically open if chamber pressure exceeds 242 kPa and the P-2 alarm will sound, and in case that fails, a secondary safety valve will open as a backup precaution should chamber pressure exceed 262 kPa. Similar functionality exists for heat and electrical levels, as well as a sensor to prevent chamber overfilling.
1ReplyThu Mar 04 2021 | manual how can I download the pdf manual for validator 8 sterilizer?Reply |
0RepliesWed Feb 15 2017 | Position What is the correct position of the Bellow Solenoid Valve (Validator plus autoclave pelton&crane) and the Dump Solenoid valve?Reply |
1ReplyWed Feb 15 2017 | Position What is the correct position of the Bellow Solenoid Valve (Validator plus autoclave pelton&crane)Reply |
[list] [*] Efficiently and compactly designed – will fit on most countertops easily [*] 4 automatic, preset sterilization controls, with optional an optional, programmable custom cycle setting [*] Variable timed drying cycle, allowing user to set dry cycle based on load size [*] Pressure-locking door design, preventing door from being opened while chamber is pressurized [*] Vent and safety valves, ensuring over-pressurized chambers are vented safely [*] Overheat protection – two independent heat-sensing mechanisms ensure internal temperature remains below 180° C [*] Electrical power interruption sensor automatically vents chamber into the atmosphere in the case of power failure [*] Chamber level sensor prevents chamber from being overfilled [/list]
| Orientation | Benchtop |
