Pelton and Crane - Validator 10+
Economical, light-capacity sterilizing unitThe Pelton & Crane Validator 10+ Autoclave is a economical, light-capacity sterilizing unit designed to accommodate the needs of small medical, dental, and other practices requiring reliable and safe access to sterilization equipment. Incorporated are a variety of safety and efficiency features, such as a door lock, which prevents the door from being opened while the chamber is pressurized. The Validator 10+ Autoclave also features a set of microprocessor-controlled features to ensure effective and safe operation; a vent valve will automatically open if chamber pressure exceeds 242 kPa and the P-2 alarm will sound, and in case that fails, a secondary safety valve will open as a backup precaution should chamber pressure exceed 262 kPa. Similar functionality exists for heat and electrical levels, as well as a sensor to prevent chamber overfilling.
FORUMSView All (7)
1Reply3 years ago | error code getting error code L6 - but no mention of this in the manual - Reply |
1Reply6 years ago | service manuel service manuel neededReply |
2Replies7 years ago | Service manual Hi, I need a service manual of Pelton Crane Validator Serie AF, somebody help me wih a copy of this autoclave? Thank youReply |
[list] [*] Efficiently and compactly designed – will fit on most countertops easily [*] 4 automatic, preset sterilization controls, with optional an optional, programmable custom cycle setting [*] Variable timed drying cycle, allowing user to set dry cycle based on load size [*] Pressure-locking door design, preventing door from being opened while chamber is pressurized [*] Vent and safety valves, ensuring over-pressurized chambers are vented safely [*] Overheat protection – two independent heat-sensing mechanisms ensure internal temperature remains below 180° C [*] Electrical power interruption sensor automatically vents chamber into the atmosphere in the case of power failure [*] Chamber level sensor prevents chamber from being overfilled [/list]
Orientation | Benchtop |
