SciCan - Statim 2000
The world’s favorite handpiece autoclaveLike the STATIM 900, the STATIM 2000 boasts a 6-minute cycle, but has the added advantage of employing a fully removable chamber so you can aseptically transport a set of freshly sterilized instruments directly to the procedure area.
The STATIM 2000 is fully automatic. Simply select one of the three sterilization programs and with a single touch of the keypad, begin the cycle. An advanced microprocessor controls all functions and maintains optimal sterilization conditions, from start to finish.
SciCan's STATIM cassette sterilizers have a biological effectiveness that has been proven in tests for hollow and solid instruments at many internationally recognized institutes in Canada, the United States, and Europe.
FORUMSView All (7)
3Replies7 years ago | service manual need how to calibrate a boiler for a statim 2000 ; newer version (2010) . board does not have any potenciometers like the older boards. No service manual . thank you Reply |
3Replies8 years ago | Statim 2000 autoclave HI, I purchased a remanufactured Statim 2000 autoclave and am attempting to set it up but have run into a roadblock. The instruction manual (for Statim 2000/5000) says to prime the pump by letting water run out of the drain tube on the underside. But my unit has no drain tube at all. I searched the web for more info and can't find anything. The dealer I bought from isn't open until Monday. Anybody know anything about this? Reply |
3Replies11 years ago | CASSETTE LEAKS REPLACED THE GASKET AND STILL LEAKS Reply |
- Ultra-fast 6 minute unwrapped cycle
- 14 minute wrapped cycle
- Exceptional instrument turnover
- 10 minute Dri-TecC drying technology
- Single use water
- Aseptic transfer of instrument directly to the point-of-use
- Reduced instrument investment
- Prolongs instrument life
Orientation | Benchtop |
