Tuttnauer - 3870EA
by Tuttnauer
Features a closed door active drying system. Perfect for multi-doctor practices, clinics or surgery centers. 15"x 30" chamber accommodates longer instruments or a large number of small instruments. Capacity for 15 full size IMS cassettes. 2 year parts and labor warranty.
6Replies10 months ago | High Temp Error Cycle fail just after watering goes into the chamber, display shows high temp error. The heat stage does not start before this error comes in. First encounter, the cycle midway and failed showing exhaust failure then now doing high temp error. Has anyone come across this problem? Equipment: Tuttnauer - 3870EA Reply |
2Replies9 years ago | water strainer gasket 3870EA Looking for part # for gasket on page 47 of the operators manual listed on MedWrench. Steve Beno, Sterilizer Services. 920-639-2753. I have left messages with Tuttnauer and no reply. Reply |
1Reply9 years ago | display Reply |
[list] [*] Closed door active drying system to maintain sterility and ensure efficient drying of packs and pouches. [*] Hepa filter 0.2 µm air filter (replaceable). [*] Rapid cycles optimize the availability of ready-to-use sterile instruments [*] Easy-to-use, single touch control system increases productivity [*] 3 Pre-set sterilization programs [*] Program and customize cycle parameters to suit your needs and maximize flexibility [*] Integrated printer for cycle documentation (optional) [*] Interdependent temperature and pressure monitoring [*] Cycle information recovery in the case of power failure or cycle interruption [*] Insufficient water detector with automatic shut-off [/list]
Orientation | Benchtop |
