Tuttnauer - 2340M
by Tuttnauer
The Tuttnauer manual autoclave is designed to compliment any healthcare facility. The bright easy to use panel was designed with the operator in mind. Their 2340M autoclave will satisfy all of your sterilization needs without compromising on quality, safety or reliability.
1Replya month ago | Maintenance Manual Downloadable maintenance manual Equipment: Tuttnauer - 2340M Reply |
7Replies9 years ago | In need of a service manual I have recently acquired a couple of these units and Im completly unfirmiliar with Tuttnauer machines so I could really use a service manual if anyone has one. Thanks! Reply |
2Replies10 years ago | service manual Reply |
[list] [*] Automatic shut off at the end of both the sterilization and dry cycles. [*] A long life electro polished chamber and door. [*] Double safety locking device prevents door from opening while chamber is pressurized. [*] Drain valve is located on the front, allowing for quick and easy draining of water reservoir. [*] Dual safety thermostat to protect against overheating. [*] International certifications. [/list]
Orientation | Benchtop |
