Hillrom - Air-Shields C-450QT
by Hillrom
Infant incubator
Hill-Rom's Air-Shields C-450QT has a microprocessor-based controller. This controller features large, bright easy-to-see displays. A keypad lock helps prevent inadvertent changes to settings. All control buttons provide tactile feedback with visual conformation of changes. The smooth front panel design is easy to clean. Radiant heat transfer between the baby and the incubator walls is decreased through this design. The inner wall can be removed for cleaning without the use of tools. A patented air curtain creates a barrier of warm air when the access panel is open. This feature allows total access to the infant while helping to minimize air temperature drop within the incubator hood.
1ReplyMon Feb 21 2022 | Battery failure Power failure when unit is unplugged but no failure code Reply |
[list] [*] Quiet Touch QT™ port door latches reduce unnecessary noise [*] Patented Air Curtain to reduce temperature fluctuations during access [*] Smooth functioning, continuously variable mattress tilts [*] Large hood for improved access [*] Removable microprocessor controller with keypad lock [*] Iris ports for ventilation tubing support [*] Auxiliary air probe for accurate air temperature measurement directly above the baby [/list]
| Height | 55 in |
| Length | 20 in |
| Weight | 168 lbs |
| Width | 38 in |
