Hillrom - Air-Shields C-100
by Hillrom
Infant Incubator
The Air-Shields C-100 Incubator has a forced air circulation system that permits stable temperature control, uniform heat distribution, humidification, protection from airborne contaminants and control of oxygen concentrations. The instrumentation includes digital temperature display and relative indication of heat output. A comprehensive visual and audible alarm system includes an alarm-test feature.
1Reply5 years ago | Alarm won't go off I have a C100 and the alarm won't shut down even if I reset it. The leds that turn on are: Probe and High Temp. Has someone had a similar problem?Reply |
3Replies7 years ago | Door latch I recently purchased a used C100 isolette. It needs a door latch....specifically the screw that runs vertically that the latch fastens around. Can I send a photo so I can be sure I am ordering the correct part? Thank you for your help in this matter. I will purchase a whole door assembly if that is necessary. Sheree Block, DVMReply |
1Reply7 years ago | Eng : fuad abu zaid dear sir or madam I have aproblem in C-100 incubator , the room temperature on display unit it is not as the real temperature inside the room ( there is a 6 degree between them can you help me Reply |
