Hillrom - Air-Shields IICS
by Hillrom
Infant warmer
The IICS provides focused heater output across the mattress to achieve uniform temperature distribution. Combined with a quartz heating element and a warming module that can be moved 65 degrees in either direction to facilitate other procedures such x-ray, the unit provides fast, reliable and uninterrupted thermal operation.
2Replies12 years ago | Skin Temp Mode Failure Hello, I need a Service Manual or assistance in solving the following issue: The unit works well in the Manual Heating mode, warming and displaying skin temperature with the skin sensor connected. However, when switched to the automatic Skin Temp mode, the heater quits working completely. The skin sensor still works during this setting, displaying the corresponding temperature as it decreases due to lack of heat output (I'm placing the skin sensor on a water balloon and comparing the temperature display with a separate thermistor reading). In addition, the unit displays "Sensor" and "Set temp" visual and auditory alarms. Thank you! Reply |
