GE HealthCare - Ohio IC
by GE HealthCare
The Ohio IC incubator contains a digital servo control. The double wall hood allows air circulation for constant thermostatic control and reduces velocity of air movement. Physical access only slightly reduces the thermostatic environment. The Ohio IC can achieve Trendelenburg and Fowler positions. The hood can be opened for full access to the patient.
[list] [*] Microprocessor controlled critical care system designed to present a more accurate, more repeatable and higher resolution control of the environmental temperature needed to manage the distressed infant. [*] Allows to achieve the desired thermoneutral environment to aid in preventing neonatal cold stress and its varied ramifications. [/list]
