Physio-Control - Lifepak 9
by Physio-Control
Innovative features include high and low energy select displays, annotating recorder that prints out time, date, leads, and gain, and Code Summary critical event record, which recaps critical events from the moment of "power on." This unit also features a Defibrillation Adapter used with auxiliary paddles for "hands-free" defibrillation. An optional Shock Advisory Adapter converts the LIFEPAK 9 defibrillator/monitor into an automatic external defibrillator for hospital codes.
5RepliesMon Aug 20 2018 | Resistor There is a resistor that connects the batteries that are wired in series. This resistor is cracked, and it is impossible to read the specs. Does anyone have those specs? ThanksReply |
3RepliesTue Jul 10 2018 | LP 9 Printer Assembly Looking for a refurb printer assembly; Part number 21300-002360. Drive gear off the motor is cracked in half causing the gear to slip and not advance the paper.Reply |
2RepliesWed Dec 13 2017 | Dont print I cant print, the printer start and stop immediately. I change the printer but it's the same I checked the board and the driver are ok , but the signal disappear after a secondReply |
| Defibrillator Type | External, Automated (AED) |
