Midmark - 625
by Midmark
Barrier-Free Power Examination Table
The Midmark 625 Barrier-Free Power Examination Table provides you with the capacity and accessibility you need to properly care for all patients without excess strain on you and your staff. And, the efficiency you need to support increased patient demand.
FORUMSView All (5)
-BMETBRO
Mon Nov 17 2025
Base Actuator
Hi all. Was doing a shroud replacement on one of these. Upon adjusting the height to get the shroud (which was pretty crunched) started hearing a grinding noise, then a bit of a pop.
Looks like the actuator is still working, the worm gear still moves when triggered, but the base no longer moves. Seems like the collar that the worm gear engages may have snapped.
I've replaced the entire motor and actuator on these when they've gone out, but this one still seems to be fully functional.
Question: is there a replacement for just the cuff/collar or even the gear portion or does the entire thing need to be swapped out?
Question 2: Is this common? I've done the shrouds multiple times and haven't experienced it. It didn't seem to take much force as in I only lowered the table about 2 inches and it went.
Any input is appreciated, thanks!
Equipment: Midmark 626 Exam Table
-FRFA
Thu May 08 2025
Chair will not go up and down all other functions seem to work
So the chair will not go up or down using either the hand or foot switch - pulled of the back floor cover - and the error code was 02 03 - I removed the lower seat upholstery and cover - but I do not see any number - is there somewhere else I should look to narrow down the problem
Equipment: MIDMARK 630
-Weesey
Mon Nov 06 2017
reset control
how do you reset wireless floor control?Reply
[list]   [*] Power height and back  [*] Unique Quick Exam® and Motion Profiling™ control features for more efficient patient positioning  [*] Paper Roll holder  [/list]
Height18 to 37 inches
Length 59.5 in to 75 inches
Weight505 lbs
Patient Weight Capacity650 lbs
Width28 in
Pelvic Tilt: 7°
