Reliance - 7000
by Reliance
In addition to examination use in medical practice, the 7000 serves another purpose as a minor procedures table. The chair reclines to a near flat position and is available with an adjustable surgical headrest.
2RepliesInvalid Date | Preventative Maintenance Looking for a check list or a preventative maintenace program for these chairs. Thanks Reply |
1ReplyInvalid Date | Main Hydrolic lift. Has any one had to repair the hydrolic lift after it has gone past the electric maximum height trip switch to where it will not go down. I starts to move down then stops with the pump running seeming to hit a hard stop? Please tell me that after I take off the seat mount and the swivel assembly that I can get into the top of the lift cover to manually remove to stoppage and lower the lift to a useable area evevation. Reply |
[list] [*] Dual side controls. Membrane switches and rotation locks control all operations of the chair from a sitting or standing position [*] Power base and top. Use finger switches or corded foot switch to raise, lower, or recline the chair [*] High and low base models available [*] Hydraulic base tested to 600 pounds [*] Auto return button returns the chair to the upright position [*] Memory Positioning Switch enables you to pre-select the chair's most used position [*] The Safety Switch prevents small children from operating the chair by disabling side and footswitches [*] Armrests lock in place. Release mechanism allows patients to sit or leave from either side of the chair. Padded underneath for comfort [*] CSA, C/US Certificate of Compliance [*] Full power articulating examination chair/minor procedure table with square base and dual controls for base and top functions, either by footswitch or membrane switches on both sides of chair back [*] Programmable memory feature for recline position and safety switch [*] Single lock adjustable concave headrest standard with choice of headrest to best fit your practice needs [/list]
