UMF - 4070
by UMF
The UMF 4070 Power Exam Table is ADA compliant, lowers to a height of 19 inches (48.3cm) from the floor and can support a patient weighing up to 600 pounds (272.2kg). The UMF Ultra Comfort Seamless Top provides security and comfort for patients and also allows for easy cleaning and helps to prevent cross-contamination.
The 4070 has a power hi-low feature which positions patients at the press of a button, and also includes a fully articulating backrest (with manually activated gas spring cylinder) for simple and easy patient position changes. An elevated leg rest pad is standard, providing additional patient comfort.
Operating on heavy-duty roller bearing drawer glides, our drawers provide dependable, convenient operation for as long as you own your table.
Height | 35 in max |
Length | 59 in |
Patient Weight Capacity | 600 lbs |
Width | 27 in |
Access Hight: 19"
