Sorvall - RC-3B
Excellent for performing general purpose applications.Sorvall RC-3B, which is an improved version of Sorvall RC-3, offers unsurpassed handiness, efficiency, and exceptional flexibility required in today's lab test centers. DuPont Sorvall RC-3B featuring H6000 rotor and buckets (6 place x 1 liter), can reach up to a maximum speed of 6,000 rpm. Other notable features of the device are electrical circuit breaker, automatic shut-off, door interlock, refrigeration, timer, and dial controlled functions. This machine with its range of features provides exceptionally smooth and quiet operation.
FORUMSView All (14)
0Replies2 years ago | Service manual I am needing a service manaul for the Sorvall RC-3BReply |
3Replies2 years ago | How to replace door lifts I need to replace the hydraulic door lifts on my RC-3B but have no idea how to access them. Can someone let me know how to get to them? Thanks.Reply |
2Replies2 years ago | Imbalance alarm The customer is experiencing an unbalanced condition. They have ran the same process for a long time and says the centrifuge is running steady. Is there a sensor adjustment for sensitivity? The customer is experiencing an unbalanced condition. They have ran the same process for a long time and says the centrifuge is running steady. Is there a sensor adjustment for sensitivity? Reply |
[list] [*] Automatic shut-off of the centrifuge motor for over-speed protection and for the refrigeration motor to prevent damage from overheating. [*] Electrical circuit breaker on the main power and control panel circuit; operating controls which may be changed intentionally or accidentally- without causing harm to the centrifuge. [*] A door interlock which prevents opening the chamber door while the rotor is in motion and/or starting the rotor drive while the door is open. [/list]
Height | 37 in |
Length | 40 in |
Weight | 627 lbs |
Width | 32 in |
[list] Max. Speed: 6000 rpm Max. Volume: 7.280g liters Refrigerant: R-502 H-4000 Rotor: 4x1000ml H-6000 Rotor: 6x1000ml [/list]
