GE HealthCare - MUSE
by GE HealthCare
The powerful MUSE travels beyond ECG database management. It’s the hub of your cardiology department, directing and managing the flow of cardiac information. Providing delivery of data. And streamlined, seamless workflow. You can pull ECG data from the acquisition device. Access serial comparisons. Analyze and confirm the data with proven Marquette analysis programs. Distribute the results, and access the patient’s electronic medical record.
4RepliesFri May 28 2021 | Setting up Acquisition Profile to import PDF or XML from Mortara ELI Link ECG machines. Hello helpers! I am attempting to branch the gap between Mortara's ELI Link (produces PDF, and XML from the ECG machines)... and MUSE import functionality. So 2 questions around Acquisition profiles... So far, I understand an acquisition profile needs to be setup for the acquisition piece for the PDFs. I am able to get PDFs into the system without issue. The problem here is that all the meta-data around the ECG is contained within the PDF title/File name, and that metadata is not coming through to MUSE. Q: Is there a way to configure MUSE to parse this metadata from the Title of the PDF file, assuming the title follows a common structure? I suspect this may have to do with editing the "Parsing Profile" xml when setting up the acquisition profile. Does documentation exist on how to create a "Parsing Profile"? I suspect this is normally done by GE rep. It is mentioned in the documentation of an "Acquisition Profile Tool", but not sure if that is a separate tool than simply creating the Acquisition Profile inside of MUSE. R^ECG_0^0_^Anja^Stit_20210222141811_31-009-1990.pdf R^{Type}_0^0_^{First_Name}^{Last_Name}_YYYYMMDDhhmmss_{DOB}.pdf Q. XML output. In order to parse a Mortara xml file, would I need just a new DTD correlating to that? Or would there be more than this needed? All the best! As always, Mike PattonReply |
0RepliesWed Apr 06 2011 | Live Patient ECG's from GE's MUSE Cardiology on Your iOS Device [img]http://www.medgadget.com/archives/img/a80iyemx.png[/img]Getting called in to check on a patient while spending time with the family is a regular part of life for cardiologists. It's also important for the patient to get a quick diagnosis of ECG readings, which is why [url=http://www.gehealthcare.com]GE Healthcare[/url] has partnered with Airstrip Technologies to link [url=http://www.medwrench.com/?equipment.view/equipmentNo/3719/GE/MUSE/]GE's MUSE Cardiology Information System[/url] with Airstrip's Cardiology app for iPhones and iPads. Using the system, physicians can look at live patient tracings whether they're on a different hospital floor or playing softball with the kids. [i]Remote ECG measurements are challenging because changes as small as 0.5 millimeters can indicate the presence of a serious or emergency heart condition. AirStrip Cardiology’s high resolution can detect such small differences through completely interactive iPad or iPhone views. Unlike traditional remote diagnostics, zooming in on waveforms does not affect visual clarity. With AirStrip Cardiology, clinical information is available from 12- and 15-lead ECGs, supporting high precision levels. Clinicians can view current data and historical tests conducted up to one year ago, in ten-second increments. Regardless of where remote cardiologists are when a critical decision is needed, they can leverage AirStrip Cardiology to quickly determine the best treatment paths for their patients. This may reduce the need to return to the hospital or access a computer connected to the hospital network. A remote cardiologist can now use AirStrip Cardiology to precisely measure ECG waveforms, helping on-site ED clinicians determine, for example, if a patient requires cath lab intervention. Based on a GE Healthcare and AirStrip global alliance for in-hospital cardiac diagnostics, U.S. hospitals can now purchase AirStrip Cardiology through GE Healthcare. The technology directly links to the GE Healthcare MUSE Cardiology Information System, a central cardiac repository that facilitates ECG analysis, supporting informed clinical decisions. A native application, AirStrip Cardiology is specifically designed for iPad and iPhone screens, functionality and mobile environments. Instead of clicking through each step with a mouse or keyboard, clinicians can use their fingers and touch to quickly zoom and switch between viewing formats. In 2010, the FDA cleared the platform behind AirStrip Cardiology. This technology is HIPAA compliant and uses state-of-the-art security protocols and cloud computing to securely transmit information rather than allowing data to reside on the mobile device, thereby enhancing privacy protections.[/i] Article Source-[url=http://www.medgadget.com]MedGadget[/url]Reply |
[list] [*] Redesigned ECG screen that closely resembles traditional paper ECG formats [*] Supports enterprise connectivity between GE and non-GE equipment [*] HL7 Interface options for ADT, orders, waveform results and billing transactions improve data consistency across all electronic records and speed billing cycles [*] Enhanced user interface and new and improved review tools help expedite your reporting capabilities [*] Display that provides access to demographics, interpretive information, and historical cardiology records – all at the click of a button [*] Comprehensive diagnostic tools to help you analyze, interpret and edit data [/list]
[img]http://www.medgadget.com/archives/img/a80iyemx.png[/img]Getting called in to check on a patient while spending time with the family is a regular part of life for cardiologists. It's also important for the patient to get a quick diagnosis of ECG readings, which is why GE Healthcare has par...
