Philips - S7-3t
by Philips
The Philips S7-3t Transesophageal phased ultrasound transducer is compatible with Philips iE33, HD15, HD11XE and HD11 ultrasound systems. The S7-3t probe can be utilized for pediatric and small adult TEE applications. It features steerable PW Doppler, as well as XRES.
2RepliesSat Aug 26 2017 | philps S7-3T Hi.. any body can help me how to repair this probe? no image. thank you Reply |
[list] [*] Transesophageal Phased Array [*] 48 elements [*] 7.0 to 3.0 MHz [*] 180 degrees Mechanical Rotation [*] Field of view: 90 degrees Philips S7-3t TEE Probe Common Errors [*] CW noise [*] Color noise and artifacts [*] Articulation failure [*] Fails leakage test [*] Fluid intrusion [*] Motor control failure [/list]
