Siemens - Acuson V5MS
by Siemens
The Acuson V5MS is a multiplane TEE transducer probe. The Acuson V5MS has a 9.6mm aperature and selectable multiple frequency imaging. It is compatible with the Acuson Aspen, Cypress and Sequoia ultrasound systems.
[list] [*] Phased array multiplane uransesophageal probe [*] Frequency 7.0 / 5.0 MHz [*] 180 degree crystal rotation that is motorized [*] Array length 45 x 14.5 mm [*] Wide bandwidth transesophageal transducer [*] Ergonomic design featuring one-hand control with variable speed rotation 90° per sec. [*] RF shielding [*] User-selectable MultiHertz imaging [/list]
| Frequency Range | 7 to 5 MHz |
| Clinical Applications | Vascular |
Compatibility: Acuson X300 PE 7.5, Acuson S2000, Acuson Sequoia, Acuson CV70, Acuson Cypress, Acuson Aspen, Acuson 128XP/10C Endoscope diameter: 10.5 mm Endoscope length: 11.0 mm Adult tip size width:14.5 mm Adult tip size height:11.5 mm
