BC Group - ESU-2000A
ESU Analyzer - Analog - Ultra-Portable - Internal Loads
The ESU-2000A test modes include RF Power and Leakage, which are measured with a large analog meter. Different color codes for each range are at the input connector and on the meter. For return contact monitor (CQM, REM, ARM, PSS) testing, BC Group has built in a 0 to 1000 Ω variable resistance with 1 Ω resolution. To improve reliability and accuracy, the ESU-2000A has no front-panel switches. Instead, the user simply changes the position of the ESM-1 switching module to select either RF Power or RF Leakage Mode. For safety, the module also blocks access to unused input connectors, virtually eliminating worry about improper connections and possible equipment damage.
FORUMSView All (3)
1Reply6 years ago | ESU-2000A Analyzer Videos May i ask if there is a video how to use the ESU-2000A Analyzer in calibrating ESU machine. Thank you very muchReply |
1Reply6 years ago | ESU-2000A Users Guide Set-up May i ask for the pictures of the actual set-up in using ESU-2000A in calibrating ESU Machine. Thank you very much.Reply |
0Replies7 years ago | Classics Never Die Great Easy to use ESU Analyzer. Analog unit easy to use and ultra portable. This unit is still sold and supported by BC Group. Only draw back is it is difficult to test some of the newer model ESU units with this system. Reply |
[list] [*] 6 Selectable Loads from 50-500 ohms [*] Return Contact Monitor Test with 1 ohm steps! [*] Power, Current, and RF Leakage Measurement [*] No Batteries or Power Cords [*] Easy-to-read color-coded meter [*] ESU Accessory Kit [/list]
Analyzer/Simulator Type | ESU |
