BC Group - DPM-2200
by BC Group
Digital Pressure Meter
The DPM-2200 Series is a high-precision, microprocessor-based family of digital pressure meters, engineered for biomedical engineers and clinical equipment specialists. Designed for advanced pressure monitoring applications, the DPM-2200 Series accurately measures both gas and liquid pressure, making it ideal for use in medical device testing, calibration, and preventive maintenance.
Each unit supports up to two pressure sensors and offers an optional temperature sensor input, allowing users to measure pressure and temperature in a single, compact device. With 13 selectable engineering units, this meter provides flexible, easy-to-read pressure data across a wide range of clinical and laboratory environments. (Generated by AI)
Measures positive and negative pressure in both liquids and gases
Supports one or two pressure sensors for dual-channel monitoring
Optional temperature sensor input for combined pressure/temperature readings
Displays results in 13 engineering units including PSI, inHO, cmHO, mmHg, and more
Ideal for testing ventilators, anesthesia machines, respiratory equipment, and medical gas systems (Generated by AI)
| Analyzer/Simulator Type | Pressure Meter |
