BC Group - DPM-220210010NHF
by BC Group
Digital Pressure Meter (for servicing Eye Surgery Equipment)
The BC Group DPM-23017510NFC is a high-precision, microprocessor-based Digital Pressure Meter designed for biomedical engineers and skilled technicians specializing in medical equipment evaluation and servicing. This advanced device accurately measures both gas and liquid pressures with exceptional resolution and accuracy, making it essential for biomedical equipment calibration and maintenance.
Featuring one or two pressure sensors and an optional temperature sensor input, the DPM-23017510NFC allows users to monitor pressure and temperature simultaneously within a single, compact device. Its intuitive interface provides multiple engineering unit displays, ensuring versatile and precise readings across a wide range of medical applications. (Generated by AI)
  • High-resolution measurements for gas and liquid pressures
  • Support for multiple engineering unit displays
  • Optional temperature sensor integration for comprehensive diagnostics
  • Rugged, reliable design built for medical equipment service environments (Generated by AI)
Analyzer/Simulator TypeEye Surgery
