BC Group - DPM-2300
Digital Pressure Meter
The DPM-2300 series is a Microprocessor based high precision, high resolution digital pressure meter. These meters measure both gas and liquid pressures and provide multiple engineering unit displays for the results. The unit may have one or two pressure sensors and an optional temperature sensor input to measure pressure and temperature all in one meter.
[list] [*] Large Graphics Display With Cursor [*] Selection Of Options And Setup Of Parameters [*] 0.05% FS Pressure Accuracy [*] Standard Pressure Scales Include 13 Different Engineering Unit Ranges (PSI, mmHg@0C, mmHg@20C, inHg@0C,inHg@20C, cmH2O@20C, inH2O@4C,nH2O@20C, inH2O@60F, kg/cm2, Kpa, Bar, mBar) [*] MAX And MIN Pressure Value Capture And Storage [*] Digital Calibration No Pots To Turn [*] Selectable Display Options And Digit Sizes [*] Battery Life Display (0 To 100%) [*] Programmable Digital Filter [*] Display Contrast Is Software Adjustable [*] 24 Bit Measurement [*] Digital Zero Adjustment No Pots To Turn [*] Dc Analog Output (Optional) [/list]
Analyzer/Simulator Type | Pressure Meter |
