BC Group - IPA-1000 Series
by BC Group
Infusion Pump Analyzer
The IPA-1000 Infusion Pump Analyzer Family is engineered for accurate, efficient testing of intravenous (IV) infusion pump flow rates, making it an essential tool for biomedical engineers, clinical technicians, and medical device service teams. Capable of testing up to two infusion pumps simultaneously, the IPA-1000 uses the volumetric method in milliliters per hour (mL/h) to ensure pumps operate within manufacturer-specified tolerances.
Each test is automatically controlled and calculated by an onboard microprocessor, delivering precise, real-time flow rate measurements. Designed for ease of use and durability, the IPA-1000 features a completely unobstructed fluid pathfor easy cleaning and maintenance. Its rugged plastic tubing offers improved durability over traditional glass components, while interchangeable cables and chambers enhance flexibility and reduce downtime.
Each chamber is auto-recognized when plugged in, and its calibration data is stored electronically, allowing for full interchangeability between units without manual recalibration. (Generated by AI)
Dual-channel testing for two infusion pumps at once
Volumetric flow measurement in mL/h with microprocessor-controlled accuracy
Unobstructed, easy-to-clean fluid path
Durable plastic tubing – no fragile glass components
Auto-identifying interchangeable chambers with built-in calibration memory
Portable, rugged, and user-friendly design for clinical and field environments (Generated by AI)
| Analyzer/Simulator Type | Infusion Device |
