BC Group - ULT-2010
by BC Group
Ultrasound Leakage Tester
The BC Biomedical ULT-2010 is the base model in the ULT-2000 Series, designed to perform electrical safety testing on all types of diagnostic ultrasound transducers—completely independent of the ultrasound machine. This stand-alone analyzer is ideal for biomedical engineers, clinical technicians, and medical equipment service teams who need a reliable, accurate, and portable solution for verifying the electrical safety of ultrasound probes.
The ULT-2010 allows for comprehensive preventive maintenance, performance verification, and compliance testing on a wide range of ultrasound transducers, helping healthcare facilities ensure patient safety and equipment reliability. Its easy-to-use interface and flexible design make it a go-to tool for hospitals, clinics, and biomedical service providers.
With the BC Biomedical ULT-2010, biomedical engineers can confidently test transducers without relying on the ultrasound system, streamlining workflows and improving testing efficiency. (Generated by AI)
[list]  [*] Tests the Upper & Lower Leakage Current Limits per Ultrasound Mfr.Specifications     [*] Range 0.5 to 500 uA - Designed to Meet Mfr. Transducer Specifications     [*] Large Graphic Display w/Backlighting Allows Easy Selection of Options & Setup of Parameters     [*] User-Selectable Challenge (Test)     Voltage (90 to 275 VAC) & Frequency (50 or 60 HZ)     [*] User-Selectable Test Limits     [*] Programmable Test Limits Based on Ultrasound Transducer Mfr. & Type     [*] 1% F.S. Range Accuracy     [*] Auto Ranging for Enhanced Accuracy Over Entire Range     [*] Single Button Press for Full System Test     [*] Selectable Pass/Fail or Numerical Test Results     [*] User-Selectable Display Options     [*] Programmable Backlight Timer     [*] Flash Programmable, Field Upgradeable     [*] Compatible with Dale Technology® & Fluke Biomedical® Adapters & Probes     [*] RS232 Interface     [*] PC Utility Software for Configuration     [*] Setup & Remote Control     [*] Test Results Printable with Optional Printer     [*] On-Board Clock & Calendar Function for Date/Time Stamp of Test Records     [*] On-Board Storage for up to 99 Test Records     [*] Audio-Visual Test Status Notification  [/list]
Analyzer/Simulator TypeElectrical Safety
