BC Group - ULT-2020
by BC Group
Ultrasound Leakage Tester with Meter Mode & Logging
The BC Biomedical ULT-2020 is the enhanced model in the ULT-2000 Series, featuring Meter Mode and datalogging capabilities for advanced testing and data management. Designed to perform electrical safety testing on all types of diagnostic ultrasound transducers—independent of the ultrasound system—the ULT-2020 is an essential tool for biomedical engineers, clinical technicians, and medical equipment service professionals.
With its stand-alone design, the ULT-2020 enables precise, reliable testing of ultrasound probes across a wide range of makes and models. The added Meter Mode provides detailed real-time measurements, while built-in datalogging ensures accurate record-keeping for preventive maintenance, compliance testing, and performance verification.
Ideal for use in hospitals, clinics, and biomedical service departments, the ULT-2020 Electrical Safety Analyzer helps streamline workflows, improve testing efficiency, and ensure patient safety and ultrasound system integrity. (Generated by AI)
1ReplySat Sep 12 2015 | data logging can we get the test results to store on a connected PC? Reply |
[list] [*] Tests the Upper & Lower Leakage Current Limits per Ultrasound Mfr.Specifications [*] Range 0.5 to 500 uA - Designed to Meet Mfr. Transducer Specifications [*] Large Graphic Display w/Backlighting Allows Easy Selection of Options & Setup of Parameters [*] User-Selectable Challenge (Test) Voltage (90 to 275 VAC) & Frequency (50 or 60 HZ) [*] User-Selectable Test Limits [*] Programmable Test Limits Based on Ultrasound Transducer Mfr. & Type [*] 1% F.S. Range Accuracy [*] Auto Ranging for Enhanced Accuracy Over Entire Range [*] Single Button Press for Full System Test [*] Selectable Pass/Fail or Numerical Test Results [*] User-Selectable Display Options [*] Programmable Backlight Timer [*] Flash Programmable, Field Upgradeable [*] Compatible with Dale Technology® & Fluke Biomedical® Adapters & Probes [*] RS232 Interface [*] PC Utility Software for Configuration [*] Setup & Remote Control [*] Test Results Printable with Optional Printer [*] On-Board Clock & Calendar Function for Date/Time Stamp of Test Records [*] On-Board Storage for up to 99 Test Records [*] Audio-Visual Test Status Notification [/list]
| Analyzer/Simulator Type | Electrical Safety |
Philips Ultrasound Validates BC Group’s Ultrasound Leakage Tester and Probe Adapter
