Toshiba - Aquilion 8
Generates highly accurate images faster and with more detail then any other comparable CT scannerUtilizes the patented Quantum detector, which delivers 32 mm of coverage with 8 x 4-mm slices. For high-resolution isotropic imaging, system acquires 8 x 0.5-mm slices, resulting in ideal volumetric datasets. [i]Can be upgraded to the Aquilion 16 onsite.[/i]
1Reply3 years ago | V7.0 Software + BASE Hello, I need a software and BASE image (like *. iso or other) for Aquilion Lightning V7.0 or higher. Someone will share? Please contact me at mhc3600@o2.plReply |
Type (configuration) | Multislice |
Slices | 8 |
Maximum Scan Range | 180 cm |
Gantry (Max. Clearance) | 72 cm |
Patient Weight Capacity | 450 lbs |
