Toshiba - Aquilion CX
by Toshiba
Presents the latest state of technological innovation in Multi Slice CT technology.
Designed for outstanding performance the new Aquilion CX comes standard with highest performance allowing clinicians to improve their clinical results with fewer resources in less time with less patient dose. A host of exclusive, ergonomic features increase patient comfort and operator convenience while making procedures safer and more efficient.
-Viktor Panin
7 years ago
Toshiba Aquilion rx,cx,64 Adv Eng Password.
Hello. Need a System Config and Adv Engineer Password for Toshiba CT scanner Aquilion CXL (64). I have a problems with software installation and configuration. Thanks in advanced.Reply
-etiam
9 years ago
protocole of exams on acquillon CX 128 slices
hi  it  is  possible  to  have  acquisition protocol  on  PDF  format  for all  body  part exams  on  children  an  adult?
best regards
[list] [*] Premium 64 row Quantum-detector technology [*] Industry's best low contrast resolution of 2 mm [*] 72 kW generator with 350 ms rotation for increased flexibility [*] Up to 28 images per second reconstruction provides results in an instant [*] High definition coneXact 128-slice reconstruction with 0.31 mm Z-resolution [*] QDS noise and dose reduction for an effective patient dose reduction of 40% or more. [*] Advanced automated SURETechnologies such as SURESubtraction and SURECardio Prospective for better results at lower dose [*] PhaseXact a unique method for full automatic "Best Cardiac Phase" selection ánd reconstruction [*] 660 lb. patient weight capacity and the industry's widest couch increase your ability to accommodate larger patients [*] Gantry and couch return to home position automatically with the push of a button [*] Convenient front and rear table footswitches* facilitate a more efficient workflow [/list]
Type (configuration)Multislice
Maximum Scan Range200 cm
Gantry (Max. Clearance) 72 cm
Patient Weight Capacity660 lbs
NEWSView All
TOSHIBA’S ENCORE VeloCT CONSOLE RECEIVES FDA CLEARANCE
VeloCT Brings Latest Dose Reduction and Workflow Enhancements to Aquilion 32, 64 and CX
