Toshiba - Aquilion LB
by Toshiba
Broadening Patient Care
The 16 slice Aquilion LB features the industry's largest gantry aperture of 90 cm and the industry's largest scan field of 70 cm, covering more anatomy with greater accuracy ever seen before.       The unique 70 cm scan field, up to 40 percent greater than other large bore CT systems, ensures superior image quality across the entire image and eliminating hidden anatomical areas for improved diagnoses, simulation and planning. Only the Aquilion LB delivers a true Field of View of 70 cm without requiring extrapolation algorithms by virtue of Toshiba's renowned Quantum Detector technology.
-Toshiba AQ16
Fri Apr 15 2022
Toshiba AQ16
Getting error code 0xb2300000 dev[0x00010002] Pno[0] Rebooted computers and unit no success any ideas what else I might can try?Reply
[list]   [*] 90 cm wide bore   [*] Enabling a breast board tilt of up to 25 degrees   [*] Radiotherapy table top* with indexed patient positioning system (IPPS)   [*] Scan range of 175 or 194** cm   [*] Low noise direct drive for 0.5 sec/rotation   [*] Maximum 70 cm scan Field of View with full image quality   [*] Up to 85 cm display Field of View reconstruction for oncology applications   [*] 0.35 mm voxel resolution   [*] Versatile in scan slice width: 16 x 0.5 mm, 16 x 1.0 mm or 16 x 2.0 mm   [*] Quantum detector material with highest sensitivity for best low contrast resolution (2mm at 3 HU)   [*] Powerful X-ray tube: 7.5 MHU MEGACOOL   [*] SUREExposure, advanced body contour dose reduction technology   [*] Quantum Denoising Software, dramatically reducing exposure dose, while maintaining image quality   [*] Boost3D is a separate filter algorithm developed for regions with high attenuation and can be combined with other filter as standard QDS.   [*] Varian RPM camera for 4D respiratorigated imaging (prospective or retrospective)   [*] Unique full automatic 4D multiphase reconstruction* (no xml-file import required)   [/list]
Type (configuration)Multislice
Slices16
Maximum Scan Range180 cm
Gantry (Max. Clearance) 90 cm
Patient Weight Capacity450 lbs @ +/-0.25mm translational
