GE HealthCare - AMX II
by GE HealthCare
[b]Totally Mobile[/b] [list] [*] Operates bedside at full power with auxiliaries without a power connection. [*] Variable speed, forward and reverse. [/list] [b]Versatile Power[/b] [list] [*] Constant-potential output makes 100 mA rating equivalent to 200 mA single phase conventional generators. [*] Rechargeable battery pack has a capacity of 10,000 mAs measured @ 100 kVp; proportionally more mAs at lower kilo voltages. [*] Silicon high-voltage rectifiers and solid state timer for consistent results. [*] Solid state high frequency inverter. [*] Overload protection for high-voltage components and battery pack. [/list]
4RepliesThu Jun 20 2024 | Battery Charger Schematic I have an issue with my AMX II, when set to charge the fan does start however the charge indicator light does not light up. I believe there is an issue with the battery charger electric board. Does anybody has had a similar problem, or can anyone provide the board schematics Reply |
1ReplyThu Feb 29 2024 | Why not exposing Why not exposing Equipment: GE HealthCare - AMX II Reply |
0RepliesMon Feb 26 2024 | Common problems Common problems Equipment: GE HealthCare - AMX II Reply |
[list] [*] 110/125 volts 50/60 Hz [*] Self contained batteries [*] Self contained charger [*] Self-propelled [*] 50-110 KVp [*] 1-300 MaS [*] Mast swivels and extends [*] Tube swivels and rotates [/list]
| Weight | 810 lbs |
