Draeger - Evita XL
Excellence in VentilationThe Dräger Evita XL is designed to deliver a comprehensive array of both controlled and assisted ventilation modes. The Evita XL combines a broad range of performance capabilities with many advanced application functionalities, providing outstanding ventilation therapy and easy-to-use operation encompassing the entire scope of the ventilation process. The Evita XL helps caregivers find optimal ventilation settings, supports the weaning process and improves caregiver workflow.
FORUMSView All (21)
2Replies2 years ago | Touch screen calibration How can i calibrate touch screen of evita xl?Reply |
1Reply3 years ago | O2 sensor How to locate the o2 sensor Reply |
0Replies3 years ago | EVITA XL Need configuration foe installing the evita xl battery need the configuration with the board in the middleReply |
- NIV plus - Innovative non-invasive ventilation
- Help Prevent complications
- Stabilize the patient
- Recover quickly and comfortably
- Wean from ventilation
