Draeger - Evita 2 Dura
by Draeger
An advanced intensive care ventilator with simple and versatile operation.
The Evita 2 dura is an advanced intensive care ventilator with simple and versatile operation, a highly responsive flow trigger, and an open breathing system that gives both the patient and the clinician "Room to Breathe". The standard color screen provides enhanced monitoring. The Evita® 2 dura can be custom built to your order. Features like enhanced graphics, integrated CO2 monitoring or specialized modes like APRV can be added to the system at any time without changing the profile of your device.
FORUMSView All (8)
-AudiBiomed
3 years ago
turkish manual is OM not SM
The 'service manual in Turkish' is an operators' manual, not a service manual, just FYIReply
3
-VN
5 years ago
mechanical ventilation
There are two devices dräger evita 2 dura. One is not working, the second is working. On one, the flow sensor is not calibrated, writes: calibration filed - measurement inop. On another device, this flow sensor is calibrated OK. Something with the device. Help advice.Reply
6
-manoj kumar
6 years ago
service manual
i need drager evita 2 dura and drager evita xl service manual .if anyone had please send me manojbmed@gmail.comReply
[list]  [*] Spontaneous breathing strategy - One of Evita 2 dura’s strengths is its implementation of our "Room to Breathe" concept. Spontaneous breathing reduces the risk of atelectasis and improves the ventilation/perfusion ratio by maintaining a higher functional residual capacity. BIPAPTM*/PCV+, the universal mode for ventilation and weaning, gives a patient the freedom to breathe spontaneously at any time. AutoFlow®, the next step in volume-oriented ventilation, encourages spontaneous breathing in all volume modes and another option, Automatic Tube Compensation (ATC), gives a patient the feeling of virtual extubation by eliminating the work involved in breathing with a tracheal tube.  [*] The right mode for every patient - Since an Evita 2 dura can be used to ventilate neonatal, pediatric or adult patients, it is the ideal “workhorse” for everyday clinical routine. The wide range of patients covered also reduces the amount of staff training required and ensures a greater flexibility in the use of resources.  [*] Two-in-one ventilation - Mask ventilation can assist the weaning process by reducing the reintubation rate or even preventing intubation in the first place. The option of mask ventilation (NIV) adds to an Evita 2 dura’s versatility so an ICU only requires one device for conventional and non-invasive ventilation.  [*] Everything in view - The Evita 2 dura provides patient and ventilator-related monitoring with user interaction reduced to a minimum. The high-resolution full-color screen displays comprehensive information on a patient’s status, always showing two ventilation curves and six monitored values, and the screen configuration can be customized to show the most important values for a particular ICU.  [*] One knob, simplified settings - This ventilator has a clearly arranged front panel consisting of a monitoring screen and various setting soft keys. The rotary knob plays a key role. The active setting parameters are visible at a glance and changes can be made by the well-established “select-adjust-confirm” principle.  [*] Ventilation at a glance - The principle of only showing the necessary parameters reduces the complexity of everyday monitoring. Additional functions are located in the various screen menus. The ventilator provides you with a full-text message in the event of alarms so you have a clear idea of the problem.  [*] Simpler and speedier standard procedures - The Evita 2 dura contains numerous functions to speed up and simplify routine procedures. Start-up settings can be configured to specific ICU practices. Suction procedures are simplified with the touch of a button, the exhalation valve can be changed in seconds to minimize downtime and sensors are automatically calibrated daily. However, manual calibration is also possible without interruption to ventilation. All these functions assist in reducing time for standard procedures.  [/list]
