Stryker - 1550
by Stryker
The Stryker 1550 Stretcher has electric knee and back. You can use the select patient controlled adjustments to make it like an electric hospital bed or the manual controls to use it as a standard gurney.
2RepliesWed Mar 12 2014 | 1550 bed Need parts list stryker Reply |
[list] [*] Litter Positioning: Electric [*] Agency Approvals: US UL, Mattress #SP-5060-U [/list]
| Height | 35 in High, Low 22 |
| Length | 83.5 in |
| Patient Weight Capacity | 500 lbs |
| Width | 34 in |
Brackets: 0-70 deg. Manual Backrest: 0-90 deg. Knee Gatch: 0-30 deg. Trend/reverse Trent: +/- 18 deg. Patient Surface: 30" x 75.5" Side Rails: 13" x 55" Caster Diameter: 8"
