Invivo - Precess 3160
DON'T SETTLE FOR A COPYThe Precess was developed from the ground up for MRI use. Wireless SpO2 and Peripheral Gating, advanced low profusion technology, adult, pediatric, infant and neonatal grip sensors. Easy to use cardiac and peripheral gating interface can be adapted to leading MRI systems. Every componet of the monitor is designed to withstand this harsh environment. The quality is represented by Precess 5,000 Gauss compatibility regardless of parameter configuration. Precess is the first MRI monitor to debut a smart battery management system. This system displays the battery life for each device, which eliminates problems while increasing patient safety. All devices feature user replaceable batteries which allow for continuous battery operation. Wireless ECG and SpO2 feature shorter cables designed to increase thoughput. Shorter cables also reduce the risk of cable heating and are less prone to damage. Precess delivers the new standard of MRI Patient Care.
FORUMSView All (14)
1Reply6 months ago | Wireless communication from Monitors to base platform lost... Hi guys, We received a system here with one base and two monitors Imain and remote monitor.. It all worked easily for a few months and suddenly lost wire communication between the base cart and the two monitors (remote and main). now it shows X's on the modalities on the screens and the connection light on the base cart is blinnking like it cannot find a connection to the monitors. Have anyone had this connectivity issue and have an idea what to look for? I was thinking a link NIC or something.. Both sides are on network 1 and monitors and base cart connec5tivity light only blinking.. Seems possible NIC on the base cart since both monitors are not connecting.. Thoughts? mrstan Reply |
1Reply2 years ago | Services Manual Services manual for the Process 3160 Reply |
3Replies3 years ago | battery where to buy? Reply |
[list] [*] Wireless 2.4 GHz Dual Lead ECG [*] Wireless 2.4 GHz SpO2 [*] Wireless 2.4 GHz Remote Monitor [*] Quick Connect Accessories [*] Non-Invasive Blood Pressure [*] Dual Invasive Blood Pressure [*] Low Flow End-Tidal CO2 [*] Anesthetic Agents with Auto ID [*] FiberTEMP continuous temperature [*] Cardiac and Peripheral Gating [*] MRI Compatible Recorder [*] 3.0 Tesla Compatible [*] Intuitive Operating System [*] No Installation Required [*] Advanced DSP Gradient Removal [*] Battery Management System for continuous battery operation [*] Large 12 inch (30.5cm) color display [*] 5000 Gauss Compliant [*] User Adjustable Wireless Networks [/list]
