Advertisement
GE Healthcare - Signa OpenSpeed 0.7T
Manufactured by GE Healthcare
0.7-tesla supercon open scanner
The G.E. OpenSpeed 0.7T High-Field Open MRI takes on the architecture of the traditional (both sides opened) Open MRI scanner. Most Open MRI scanners operate at a lower magnetic field strength and receive a lower signal from the body. High-field MRI scanners rely on the tubular or cylinder form construction to produce strong magnetic fields. By using superconducting technology, the magnetic field strength of the G.E. OpenSpeed High-Field Open MRI has been increased to 0.7 Tesla. This is two to three times stronger than the traditional open MRI systems operating today. With the combination of high-performance surface coils and powerful computer processing power, the performance of this scanner is equivalent to that of a 1.0T High-Field MRI system. As opposed to the traditional open MRI systems, the images on the G.E. OpenSpeed 0.7 High-Field MRI have a higher quality and are done in a shorter time (3 times faster than most other Open MRI systems).
QUESTIONS & ANSWERSView All
2
Answers
-JonP3RS
5 months ago
second hand value
Hi, I am a general contractor. I am renovating an MRI suite and removing a .7T MRI. It is a functional magnet now. Does it have any resale value? Can it be parted out or sold as a 2nd hand system?Reply
Answers
-Alebar
a year ago
GE .7 Openspeed MRI
What is the highest temperature that the equipment control room be?Reply
Answer
-DSaxena
2 years ago
Vibration Threshold
Need specifications to look up the vibration damage threshold. The model # is 221300.Reply
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
  1. Patient weight limit of 227 kg (500 lbs)
  2. 0.7 Tesla magnet (length: 175 cm (5’9”))
  3. Bore (tube) diameter 212 cm(W) x 250 cm(H)
  4. Magnet weight incl. Helium only approx. (8,256 kg (18,200 lbs))
Clinical UseWhole Body
Magnet TypeSuperconducting
Magnetic Field Strength0.7 T
Patient Weight Capacity500
Weight18200 lbs
NEWSView All
!{article.title}
GE Login Tips from Conquest Imaging
GE login tips from Conquest Imaging
!{article.title}
GE Healthcare Launches the Most Sensitive Clinical PET/CT Scanner in...
GE Healthcare is proud to announce the new Discovery† PET/CT 610 as the first double-digit sensitivity PET/CT scanner* with an absolute sensitivity of 10cps/kBq1, the highest level found on any scanner commercially available.
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
